Engine/Transmission (1998.5 - 2002) HELP - is my new t-stat bad???
Engine/Transmission (1998.5 - 2002) 275 injectors
Engine/Transmission (1998.5 - 2002) void sticker
Hey guys,
I have put in two new 180* thermostats in the last two weeks and both of them cause my truck to have 15* swings in coolant temps. Anyone know what's wrong? I can't imagine that both t-stats are bad, but maybe they are. Coolant temps cycle between 180* and about 165*. The t-stat part number is 3954194. My old 190* never did this. Any ideas?? Thanks guys!
Steve
zman
I have read that our trucks only use about 20 to 30 % of the cooling system while not towing so I think what you are seeing is that when the t-stat opens it lets cooler fluid in and then your motor temps drop, I wouldnt worry about it if I were you. I have witnessed this myself for the first 10 to 15 miles of a winter trip.
cheers, Kevin
Steve, long time no talk.
I put in the new 180 as well when I changed my coolant and got the same results, at least 15* swings. The old style thermostat that came in my truck went up to 190, dropped to 170, up to 180 and never moved. This new one swings until I shut it off no matter what the conditions. Nature of the beast with the new style thermostats.
Steve,
Both T-stats were ok, the coolant has 6 gals in it so when it is cooler out, the swing is longer especialy at idle.
I make a winter guard that fits in the openings of the grille to restrict the airflow to keep the coolant at a more moderate temp. Also to help it warm up faster.
Here is the link to the classified ad for them
https://www.turbodieselregister.com...display_db_button=on&db_id=21&query=retrieval
E-mail me if you'd like a set
Eric
hmmmm....
I would agree that both of the 180* t-stats are probably good, but why didn't the original 190* t-stat act like that? Seems like I read somewhere that the new 190* t-stats are 2 stage - they open up partially under no load and fully under a load (higher coolant temps) in order to maintain a steady coolant temperature. Anyone else remember seeing this somewhere?
Steve
