Engine/Transmission (1998.5 - 2002) Help? is my transmission going bad?
Engine/Transmission (1994 - 1998) Transmission parts????
Engine/Transmission (1998.5 - 2002) Slow to Start
I have about 155k now on my truck and use it to tow a 12,500lb 5th wheel. Normally it tows great. I can hang with my friends v10 ford, and he tows a lighter travel trailer.
This weekend we went for a trip and from a stop my truck was a DOG! I had to put accelerate to 2000 RPM"S and a few seconds before it would move. It was like I had an anchor behind me.
If I did not come to a complete stop it was fine, Normal acceleration.
I thought maybe one of my brakes was locked up so when I got home I jacked up the wheels on my trailer and could spin every one without a problem. I also checked the brakes on my truck the same way, and they are not sticking.
Is my transmission going bad. I have never had one fail before, so I'm not sure what the symptoms are. Any ideas on other things that could be wrong.
I do have a suncoast low stall converter(not in my sig)
Thanks!!
Moderator, I posted this to the wrong forum!! can you move it to the 12 valve engine and transmission forum???????
Sounds like 2nd gear starts - Replace govenor soleniod and sensor - About $200 for parts ( in trans valve body and easy to do with trans pan removed) plus transmission fluid.
Tom
