Help! Isuzu/LUV has no power!
200k on a 6.5 diesel Blazer?
It just don't look right
If it is an Isuzu C223T engine, the thing is running at point break already. I have one in my 86 Trooper II. Nothing works except for making more smoke. I'm working on using a VW TDI intercooler on it for better mileage.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
You know, if one was to just reply to the title... The definitively correct answer is:
"We know that already. Now what's your point?"
If the pump is similar in appearance to the VE pump used on the first gen, the fuel screw is in the same place.
If your truck has an inline pump, then adjustments are not for you. #ad
To make more power with your engine, you need to open up the exhaust and intake... A K&N air filter plus a more open exhaust will get you the ability to handle a bit more fuel.
[This message has been edited by Power Wagon (edited 04-30-2001). ]
HA HA Powerwagon. It's not mine,just trying to help make it a little safer. Dam thing won't get out of it's own way. So are you saying if it looks like a VE pump then it is a VE pump or?
I have no idea what was done to it, but I had a 81' Luv diesel that wasn't a pooch. The black smoke would roll but for a little truck it did run pretty well. BTW it was a one owner /w/ about 40,000 mi. on it for what it's worth.
Well, yeah. If it looks like one, it is... but it's not made by Bosch, just licensed by Bosch. Having seen one maybe once in my life, I can't tell you right up front what's in it, because I don't remember. Some of those japanese VE pumps have more screws and stuff hanging off them than carb... but if you look real close, the fuel screw is the fuel screw, and it's in the same place.
ha ha I had one of those and you are so correct that they can't get out of their own way !! But my fuel milage was at 29 with it #ad
96 2500 4X4, SC, SLT, 12 valve,lost kitty, silencer ring gone, 5SP 3. 54. dana 80, Pac Brake with 60 pound valve springs, line-x liner, soon to come: Auto meter ultra lite boost and pyro gauges on A pillar,
Currently have a '81 with about 264,000 and still manage 30-33 mpg. Do not try to set speed records even though did get some speeding tickets in it. Just relax and let it get out of it's own way when it gets there.
