Help, it won't shut off!
Anyone come up with a good homebrew setup for boost to fuel pump tube?
Killed my KDP today.
PToombs
Drove to work today, let it run for a minute in neutral. Turned off the key and the radio went off, hey! the truck is still running. I turned the key a couple times and nothing. I put on E-brake got out and shut off w/ the lever (gotta love a first gen!). Drove home, same thing. Is there something stuck under the shut off seal? Or is it rubber and tore or wore? It's a pain to open the hood every time and it doesn't stall too easy. Any help would be appreciated, TIA.
Looks like the tip of the rubber plunger in the shutdown solenoid has been blown off or is worn not shutting off the flow of fuel to the engine. Take it out and inspect.
Thanks Bill, thats what I thought but I wasn't sure. I was going to fix my tank straps, change the rear brake line and make the ABS go bye bye this weekend, so I'll add this to the list. Thank goodness I work for a CASE dealer, I get parts at cost. :)
