Hello, well I may get scolded for being in this forum. But I need help in the worst way and somewhat in a pickle. Due to lack of Kenworth support I will need to once again rely on my Dodge bretheren to help. True this truck is not a Dodge, but it does have a Cummins. The truck is a 2011 Kenworth T800. The problem is that I need to find a place to splice into the left and right signals to get a solid 12volts. I need this voltage to trigger a relay on an onboard computer. Everything I have found in the dash is electronic In fact everything in the cab is electronic. There is a chassis load center somewhere, I know not where. I am thinking I should be able to pick them up there. I have been through all of the schematics that I can put my hands on, with no avail. I am going to finish this install up tomorrow morning and would like to have the answer before I get there. So if you are a KW guru or know one any help would be appriciated. Thanks Aaron
