Archived Help! Lift Pump Dying?
Archived u Joints??? Help...truck grounded...
Archived Lost both keys!!!! Now what???
Help! With my 99 2500 I noticed no power up hills (happened suddenly) so changed filter (also filled the filter) & it ran fine with plenty of power for a mile or so & reverted to no power again. I installed fuel pressure gauge & it gives me 6 psi after turning on key (I can hear the LP pump run & it shuts off at 6 psi. ) I start engine & it drops to 4>5 psi but GOES TO 0 psi when throttle is pressed. If I turn key on & it goes to 6 psi but I do not start engine it will slowly drop to 0 again (after a short pause at 4 psi. ) Could this be a faulty LP pump even though I can hear it run a short time after key is turned on or perhaps a faulty overflow valve? I'm stumped & do not have a code reader. Thanks for your help!
Most likely a lift pump, possibly a clogged in-tank screen filter.
Just had mine do the same thing. Put in an aftermarket system today.
I just need her to be reliable. The lift pump is like $170 at a cummins dealer, and not too hard to do.
Running at those pressures could very well damage the injection pump, so this is a good thing to fix fast.
I would go with one of the aftermarket systems and be done with it. I have the Glacier system on mine. I am very satisfied with it. Good luck. Jeff
