There is no fuse
There is no fuse that I know of, believe me I checked quite a bit when the first Mallory died, best I could locate was a relay for the VP44. Please, someone correct me if I'm wrong.
As it is very apparent that the dead lift pumps keep on a coming, I've decided to do something to help the members without a FP gauge. I have a bunch of spare fittings,braided line, etc. and a Jegs liquid filled 0-30 psi fuel pressure gauge (it's one of those small, 1 1/4" gauges with the 1/8NPT post fitting on the back). I'm going to put togther a temporary set up with about 6' of braided line, so that you can observe idle and WOT psi's. I'll include adpaters for the 98. 5 and 99's as well as the 2000 + years. Once I get it built, should be by this time next week if the planes keep flying, I'll put up a post and send the set up to the first needy member, who can then pass it on to the next member, so forth and so on.
Scott W.
