Lost power to Prodigy
I have the factory wire harness under the dash coupled to the connector at the back of the Tekonsha Prodigy. I was rerouting the wiring under the dash (Prodigy disconnected) when the end of the Prodigy connector shorted against metal under the dash.
I no longer have power to the prodigy but can't find any blown fuses either.
I appreciate any advice on the fix.
99 4wd, LWB, 5 speed, 3. 55 LSD
Mostly stock
Gauges: Fuel pressure, Boost, & EGT
Pusher pump
Cold idle enabled
Running boards, Custom bed cover, Rhino liner, etc, etc
Mostly stock
Pusher pump
Cold idle enabled
