I installed the BMK 15 and changed to Amsoil 15/40 this weekend. Now I have LOW oil pressure. Prior to installing and changing, the guage stayed just over the 40 mark at highway speeds. Now when first starting up cold the pressure is on the 40 mark. Now it stays about 1/2 way between the first white mark and the 40 mark at temperture and highway speeds. At idle the needle is only 2 needle widths over the first white mark. So there is very little difference from idle pressure and 1800 to 2000 rpm pressure. I checked the hose connections 5 times to be sure I had them right, I do. I drained a little oil from the petcock to be sure there was oil getting to the filter assembly, there is. Any ideas? I have 54. 8k on truck
Thanks
Ron
Thanks
Ron
