Help! Low power engine light on
A/C starts and stops frequently
Boost problem with GSK....Solved!
On my way to work today truck studerd then lost 50% power then the engine light came on. Check all gages all normall. When down road 2to 3 miles then went back to normall. But engine light still on. Went home about 15 miles started to lose power again. What should I do? What could be wrong. Any help please.
Sounds like it could be a bad boost/map sensor or just the conection to the sensor. Try and disconect the boost/map sensor from your fueling box and from the truck and spray some dyelectrical grease on the sensors and reinstall them that might help. :)
Darrell
Got the code p1693. Did a search got all the info. It was the plug going into the map senser. I unpluged it and pluged it back in . Worked great all the way to work and home. Im going to get some grease to put in it. Thanks for your help. I love TDR
