I was changing my brake pads when I discovered the drivers side lower control arm is borken, the one that attaches to the frame and the bottom bracket on the front axle of my 98. 5 4wd 2500.
If you have ever taken a soft drink can and twisted it, tearing the aluminum, then you know what this looks like. I first thought maybe I had hit something, but there is no sign of an impact, nor do any of the skid plates or other parts that are lower than the control arm.
Has anyone else had this happen? It has only been about 3,000 miles since the last oil change when it would have been noticed. I started getting a loud popping last week when braking hard so It must have cracked, then all of a sudden twisted under heavy braking with my trailer behind.
It seems like this should be a warranty item. I only have 42k miles and an extended warranty, HOWEVER, I don't want any more flimsy junk like this put on. Even my old 4wd 1/2T suburban has heaver steel. This is more like sheet metal than steel.
Does any one know of any heavy duty control arms being sold. (Does Dodge call this part a control arm or does it have a different name?) My truck is down until I can fix it and it is my only tow vehicle so I can't wait to order in, unless I can get over night delivery from somewhere. I have to have it going by Teusday.
I would appreciate any help. I am in Dallas, Tx.
