I really need some assistance; can't afford a visit to the stealer!! I have a popping noise coming inside the cab from movement in the lower steering column. I checked, and there is a lot of movement where the column comes through the fire wall to the engine compartment. Does anyone have a service manual showing what is going on under that toe plate? Could I have a bad bushing or carrier bearing where the column leaves the cab? I'm pretty sure the popping is resulting from the inner column rubbing against the outer mesh "sleeve". Can the lower column be tightend up? Is this possibly a repair I could make myself? Any and all help is greatly appreciated.
2001 2500 4x4 automatic w/ all the bells and whistles, 45,000mi.
