Archived Help.... LP gone, need to wire auxiliary
Archived No rear brakes
Archived replacing axle seal -How to remove axle
I had a Water In fuel light coming up, so I replaced filter, and cleaned bowl.
Installed everything, filled up bowl, tried to prime... nothing.
I took banjo bolt off from filter inlet and there is no fuel from LP, voltage is there, but no flow, looks like LP isdead or close.
So I ordered a Holley Blue to get me going temporarily this weekend.
Can I use harness from OEM lift pump to run the Holley ? I already have a harness. Also can I just run flow out of Holley through not working LP ?
You bet! I am running the Holly Blue from the factory pigtail. Some guys think it might be better to get a relay and run a fused line to the fuse center and power the relays coil from the factory pigtail.
