I am in the middle of the swap between the stock pan and the new Double Deep Maghytec. The directions are a little fuzzy, it takes you through the whole install, refill, check for leaks etc, and then on the next page it discusses a spacer block that is installed against the VB, and the filter is installed to the block. Any experience out there installing the Double Deep. A quick response would be appreciated!
Thanks,
Steve
Thanks,
Steve
