I changed oil on the 04 today. While doing so I took the tube off from the air cleaner to the turbo. When I did that I also unhooked the wire plug at the air cleaner housing, to get it out of the way. When I was done , I started the eng. to check for leaks and had oil pressure imediatly. However I forgot to plug in the wire , and drove a couple blocks to home, and that is when I noticed the MIL on, on the upper left side of the dash. I shut it off, plugged the wire in , started it back up and the light stayed on.
The owners manual says that prolonged driving with the light on could cause damage to the engine control system. Also affecting fuel economy and driveability.
I am 80 mi. away from any dealers or shops with any ability to work on these rigs.
I need some suggestions.
PS I am assuming that the wire unplugged caused the situation.
