help me decide extended warranty
Mm3 tuner making gauges go crazy.
FYI on the 2019 OEM Power Running boards
comrades - 2018 2500 . 34500 miles. oil leak, perhaps multiple. dealer has told me previously its the oil filter. it is not. have replaced the oil filter 2x since i took it in for the oil leak. now i have " soot " buildup between the airbox and the top of the engine. i read in the warranty info that ONLY the following is covered -
block and internal
head
core plugs
inj. pump
injectors
gaskets and seals for listed components
intake and exh manifold
oil pan
oil pump
timing gear and cover
turbo / internal parts
water pump
so , it seems to me, there are plenty of places for oil to leak etc. from NON listed above parts.
i welcome any input. i live far from the dealer. it seems like they dont want to really check on the oil leak...
thanks in advance. cheers comrades! :)
An 18 with 35k, your entire truck is still covered under the factory warranties. But yes, max care would cover leaks, once your power train warranty is over.
Use a better dealer.
Earl
You still have bumper to bumper warranty under the 3/36,000. Get FCA involved and or take it to a different dealership before you hit 36,000 miles.
comrades - i agree on different dealer. one issue is live up in the mountains far from dealer...the other issue is that they legalized dope in colorado and that is proving to be a significant problem in finding any capable employees in many industries.... cheers! thanks for the input.
