OK, I was a member here a while back, and have recently rejoined the party. All this time I have been studying various posts to get an idea of my next power mods. I think I have a list of items, but if I could get some sound advice regarding the best approach and which vendor is most likely to be of the most assistance...
So I have some $$$ that the missus is allowing me to spend on the truck. :-{} As you can see in my sig, I have done some work but I need more power
. Here is what I have determined should be best for me:
Turbo - HTB2 14/62
F1 injectors (130 or 150 hp?)
pulse manifold
intake elbow (ATS)
banjos
Smarty
4" exhaust
I do a bit of towing about 1 - 2 times a month, generally no more than 5K lbs, but sometimes it could be more like 8K lbs. I intend to leave the existing mods in place. Future plans may include propane and/or meth.
My biggest concern is whether the turbo is right for me and which injectors I should settle on. With the comp on full, I anticipate around 425 - 450 hp total (correct me if I am wrong), which would be about right for the turbo. Although, if I turn down the power on the comp (for towing, etc), then will I have too much turbo? Also, with this set up, will I have enough turbo to use the fuel of the Mach 4s, or will I see better use of the Mach 3s?
And finally, who would stock all these various components so I can work with one supplier?
Thanks
Byron
Turbo - HTB2 14/62
pulse manifold
intake elbow (ATS)
banjos
Smarty
4" exhaust
Thanks
Byron
