after YOUR TRANS HAS REACHED A CERTAIN LEVEL, THE TORQUE CONVERTER LOCKS UP USING TRANS FLUID PRESSURE TO PUSH A DISC AGAINST THE TORQUE CONVERTER HOUSING. NOW YOU'VE ELIMINATED THE FLUID COUPLING THAT ALLOWS SLIPPAGE. THERE IS LESS HEAT BUILDUP WHEN IT IS LOCKED. TBOB
