HELP, my truck will not start...now I am stumped
1. OK guys, here is the deal...
I ran down this morning and she fired right off just like normal. I ran back in the house, grabbed my coat and all the other junk I take with me every day. I got back to my truck and unplugged the heater, jumped in, put all of my stuff on the seat, turned and closed the door. At this point I saw the brake/ABS lights flash on the dash and then my truck died, just like I turned off the key. Now everything seems to work ... EXCEPT the ignition switch. I turn the key and nothing happens, no radio, no clicks, nothing... (the buzzer still works if the key is in and the door is open) Lights still work, battery is still connected, all wires that I can see look ok. I didn't have any electrical smell or smoke, so I am hoping it's something simple. Could it be the ignition switch, or should I check other things first?
I don't know where to go from here, I checked the fuses under the dash, but what else??????
2. OK I have spent an hour or so digging around in the steering column and under the dash... no blown fuses, battery is at 12. 30 volts getting 12 volts to the ignition switch, and to all non-switched accessories. But when I turn the key to ON or to the ACC position it stays the same no power to anything that the key turns on. I am gonna call around and see if I can find an ignition switch I guess.
3. OK got an ignition switch... . guess what... . it didn't fix my problem, truck still dead. I don't know what else to try... . H E L P
Thanks for any input fellas
