I've had my truck in the shop for 3 of the last 7 days now trying to figure out where the major oil leaks are coming from, and after adding dye to the oil the dealer found the leaks to be at the front crankshaft, and the timing cover, and the vacuum pump.
They were planning to cover the crankshaft seal under warranty, but not the vacuum pump since I was beyond the 3/36, but then I got the call that they found this device (turnbuckle) attached to the turbo, and it is allowing too much boost and causing blow-by which is pressurizing the cases and blowing seals. Of course this means no warranty for any of it, and I pay for the diagnostic fee.
Is the dealers theory realistic ? I know that these engines take more than my max 30 psi of boost with an HX turbo, and from the looks of it I may be getting some blow-by even at idle since I have recently seen smoke from the oil vent tube.
Please share your thoughts guys.
