help - need exhaust fitting...
Billet valve cover!
275 Rv injectors
Hey all,
I am in need of a connector that will join two 4" OD exhausts pipes. I have checked everywhere in my area and nothing like what I'm looking for is available. The connector needs to be 4" ID straight through - NOT two 4" ID bells on either end of a 4" OD piece of pipe. In lieu of this fitting, I could use a very long 4" ID bell put on the end of a piece of 4" OD pipe and then cut the bell off to use as the connector. Unfortunately, I have not been able to locate an exhaust shop in my area that can work with 4" pipe.
The goal here is to be able to slip the entire connector over one of the pipes being connected, then align the two pipes being connected, and then slide the connector over joint. This will greatly ease installation and future removal of the exhaust system.
If anyone out there can either locate a straight through 4" ID connector or can create a very long 4" ID bell (6-8") from a 4" OD pipe, please send me a PM or an email. I hope this request makes sense!! Thanks!
Steve
Hey Steve- Did you try TruckPro in Indy? They should have what you need. If not the have 4"id stainless flex and band clamps that will do the same. 37 and Thompson Rd.
thanks!
Joe - thanks for the tip. TruckPro in Indy stocks a LOT of 4" stuff but not what I was looking for. :(
It looks like wsteffes found exactly what I needed.
Thanks to both of you for your help!!!
Steve
