I’ve been trying to chase down a slight lope or chug to the engine lately and the next test I’d like to do is a compression test (for more info on the problem, see the end of this message). I searched the archives back for the last 6 months and I found 4 things.
First, someone said compression should be around 400 to 460 lbs. I’ll have to see if that’s in the service manual. Anyone know for sure?
Second, DRAWSON said that Snap-on has an adapter for the injector hole to fit a compression gauge. Dee, are you there? Do you know the part number? Does Miller or someone else also have it, maybe at a cheaper price?
Third, BPINE and DRAWSON mentioned a “leak down” test. What is this and how is it done? Is it something I can do?
Finally, LSMITH mentioned pressurizing the cylinder with an air compressor with both valves closed and listening for a leak through the exhaust or intake valves. Anyone have anything to add to that?
Here’s my symptoms: The engine has a lope or chug, like I said, sort of like a gasser that has one weak cylinder. I hear it most in the 1200 to 2000 RPM range in 4th cruising around town, but I can hear it through the full RPM range. Idle is smooth, though. And it runs strong when you get on it.
My remote temperature gun shows #3 is running about 50* cooler than #2 and 80 – 100* cooler than 4, after a hard WOT run up a 6% grade about 3/4 mile long (I charge up the hill, then pull over, set the brake, pop the hood and start checking temperatures right where the exhaust manifold mates up to the head). So it appears #3 is not as strong as the others.
I suspected a bad injector, but I swapped 3 and 4 and there was no change. I’ve been suspecting the pump, but then I got to thinking maybe #3 has a gasket, valve, or (worse) ring leak. There is no obvious indication from the outside of a gasket leak. What are the symptoms of a these types of leaks?
Any suggestions?
Thanks in advance,
Jay
Any suggestions?
Thanks in advance,
Jay
