Engine/Transmission (1994 - 1998) Help needed finding trans/T-case leak
Engine/Transmission (1998.5 - 2002) S.O. Pump on a H.O. Truck?
Engine/Transmission (1998.5 - 2002) Sloppy Convertor?
Hi guys. I let my truck sit for about 2 weeks and I found a puddle of trans fluid underneath it today. I haven't had any problems in the past with it. So, I crawl underneath and it seems to be coming from where the t-case and trans bolt together. Right above the rubber trans mount where there are the bolts that bolt the two together.
I could hardly get a wrench in there to see if any bolts are loose but it didn't seem like any were loose. Right where it is leaking, there is a small hole, it kinda looks like a casting mark or something. The fluid is coming out of it while it sets. I have no idea how to stop this without tearing it apart. If there is a quick band-aid fix to this for now please tell me. Any help will be appreciated.
Thanks!!!
That is a drain hole. There is a rear transmission seal and a front T case seal in there. One of them is leaking. no big deal to fix. Pull the T case and replace both seals.
