HELP NEEDED!!! FUSIBLE LINK PROBLEM
Propane
HI,HOPING TO SOLVE PROBLEM. HAVE BAD 20GA
ORANGE FUSIBLE LINK. GOES TO RED 12GA IN IGN
CIRT. IGN SWITCH WAS REPLACED. ALL WIRE VIS
CHECKED. ANY IDEAS??? CAN'T SEEM TO FIND WHERE
THE SHORT IS. I NEED MY WHEELS,WIFE DRIVING ME
NUTS. NO WORK HAD BEEN DONE TO TRUCK BEFORE
PROBLEM. IT'S A 93W250,4X4,EXCAB. ALSO JUST FOR
INFO TO ANYBODY THAT HAS THIS TRUCK. YOU MIGHT
WANT TO CHECK A HARNESS THAT COMES OUT OF THE
FIRE WALL/BULK HEAD TO RIGHT OF BRAKE BOOSTER
AND RUNS DOWN TOWARDS FRAME. I FOUND HARNESS
BETWEEN LIP ON BULK HEAD AND INNER FENDER WELL. LIP HAD CUT THRU HARNESS AND HAD STARTED
TO CUT COATING ON WIRE,BUT HAD NOT GONE THRU
ALL THE WAY YET. IT MIGHT BE WORTH A LOOK.
THANKS,MHM
Checked the wiring diagram in the service manual, this circuit seems to run most of the electrics on the truck except the AC, power windows and headlamps. Fuses 1,2,3,7,8,9,and 10 are on this circuit. You probably have a short somewhere between the fusible link and the fuse block, this circuit also passes through the ignition switch. If you need more help email me at the link bellow.
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
