Well I finally got my truck back together with my new motor form Scheid diesel. I picked it up the day after X-mas and installed it over the weekend. It has been completely gone thru. New pistons, 14mm head studs, main studs, street cam, bearings, port job, valve springs, ATS exhaust manifold, S-3 turbo, 80hp injectors, all thru Scheid Diesel. Anyway I have had it running twice, once last night, and once just tonight. Well when I first started it up the first night all went really good. It started right away, ran smooth and didn't miss a beat. I had it running for about 30 minutes, at around 1500-1600 rpm to break the cam in. I shut it off, checked for any leaks and such and found none.
Night TWO:
Well I had the trucked plugged in (block heater) for about 2 hours and started it up to put some heat in the motor to do the final torque on the head studs. It started fine and I was letting it idle for a few minutes, then I noticed a miss (pop out the exhaust) it would blow a puff of white smoke and it did this for about 5 minutes maybe a little more. Then it seemed to go away and idle normal. I thought that since the truck had been sitting for quite some time maybe the fuel was bad? So I started to remove the valve cover so I could retorque the head studs when I noticed a puddle of black oil under the truck. I can see that it has come from the exhaust side of the turbo, looks like it seeped thru the clamp from the turbo to the exhaust pipe or out of the waste gate. So my question is what is going on?? Is it fuel, injector messed up that was causing the miss? Oil seal in the turbo? Please any help would be great. It is making me sick to my stomach.
Thanks
Dustin
Night TWO:
Thanks
Dustin
