they probably had the batteries disconnected during the pump install. try recalbrating the apps. disconnect the batteries for several hours. reconnect turn key on but do not start the engine, slowly depress the go pedal to the floor and slowly release. give it a test drive. if that doesnt work . try cleaning all the grounds, and battery cables. hope this helps. good luck.
