HELP!! No brake lights!
leaky seals
Put It In Park
I was comeing home frome the ranch today and a buddy of mine pulled up next to me and said i have no brake light so when i got home i pulled all the fues and they where all good and my lights come on and my turn signals work and i pulled the cover off the brake lights and they anit blown and they 3rd brake light dont work to, what do i do????? is there a trick to this???
99 quad cab 4x4 5spd 355 gears sandstone color K&N air filter starit pipe spray in bed liner
goose neck ball, autometer boost and egt on a piller mount and an alpine cd player- theres nothig like the smell of Diesel in the morning.
Hoss, i had a similar situation with an '84 pontiac. If you will look on the brake pedal arm, there is a switch that tells the brake lights to activate. Mine went bad in the pontiac, I looked for shorts, bad bulbs, fuses etc. The part was like $7 and fixed it. I dont know where the relay is on the dodge, but that would be the first thing I would check. I hope this helps, good luck
Shawn
1998. 5 4x4 quad LB, Rollnlock, 5spd.
thanks alot shwan, but i looked underthe hood and found the problem, the little blue box fuze is tost, thanks again. Ian
Yet another example of how great this site is. How else would we solve these little problems without this board?. Dealers must really hate the TDR for taking away all there buissness!.
