Help no brights
Managing ESPAR vs DumbAttack/ battery isolator,
Is the lift pump under the engine warrenty?
I lost my brights on my 95 4x4. I have only the indicator light. I do have a fisher minute mount snow blade, and don't have brights on either. Tried replacing bulbs, light switch, and multi swith. Also replaced relays on the plow wiring harness. any other suggestions?
tst fuel plate,16cm3 turbo housing,bd torque converter and tst transmission up grade. straight pipe and turbo,pyrometer gauges 199,743 hard miles and running strong
swampcreek,
Did you check to see if you have any power to your brights? (Test light or muti-tester)
Jump wire to bright side terminal see if they come on. (To test bright lights)
If you replaced every thing in the cab I think you have broken wire. Your lows work so the ground should not be problem.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
[This message has been edited by Missouri Mule (edited 01-13-2001). ]
