OK,
here's the story, i've been bleeding my brakes, i've pushed over 2 quarts thru and bled from every bleeder screw, i even removed the new rear calipers like Paul Herioux recommended I'm 99% sure there no air in the system, but every Time'me i hit the brake pedal it goes straight to the floor, pump it 2 or 3 Time'mes and it comes back up and seems to hold firm with engine off.
start the engine same thing happens but after i pump up the pedal and hold it, it slowly goes down to the floor, and the brake light stays on all the Time.
i just installed a NEW napa master cylinder primed the cylinder with the little tubes going back into the reservoir, re-bled the system and i get the same thing.
another thing that happens, with the top off of the master cylinder if i push on the brake pedal even lightly i get a little geyser from the forward chamber ( both old and new cylinders did the same thing).
i tried plugging both ports on the master cylinder and pushing the pedal hard as a rock won't move a 1/2 inch, question, can the proportioning valve leak between sides?? but then i did not have this problem before i started working on the brakes.
any suggestions i,m about ready to try anything
Rick D
Rick D
