Help! No go pedal, again!
What code??
Evans coolant and new hoses
Alright my fix didnt work. see this as to what my problem is
:http://www.tdr1.com/forums/showthread.php?t=160188
It happened 4 times in the last 2 days. Going down the road light throttle and then nothing for about two -four seconds motor idling, then everything fine but check engine light is on. No codes. If it was the Accelerator Pedal Position Sensor(APPS) shouldnt I get one of these codes:
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
After 3 cold starts no check engine lights.
Here is my dilema: dealer has APP Sensor in $455. 00. Do I spend that and hope that is it. Can the computer store codes and not show them on the dash? Should I pay dealer to hook up scan tool? Help, I need this fixed. I cant be left stranded if it decides to go completely. But I dont want to throw money down drain. :confused:
Took to dealer this morning pulled all codes for the APP Sensor. Bought it and am gonna replace it. Total cost= $540 They also pulled two codes out of it that I have no listing for PO122 & PO123. Anybody have any ideas?
I HAVE BEEN HAVING THE SAME PROBLEM, I JUST GOT A NEW SENSOR, 401. 00 FROM CUMMINS ROCKY MOUNTAIN, I HAVENT CHANGED IT YET, BUT I WILL IN A FEW DAYS AND REPOST THE OUTCOME... :mad:
