Help, no marker lights.
Towing videos in BlueRidge Mtns.
Tow dolly
I lost all my marker lights on the truck/trailer. I checked all the fuses, and relays dealing with it. I also switched my head light controller with my buddies and it works with his. Their are no codes(smarty/dash). What else should I look at?
Lights
Hello, I helped a guy in Canada with about the same thing,we found the fuse under the hood by the batt. was bad.
Good luck dkoldno7
I'll aso checked where the relay plugs into with a multi meter. 2 positions have constant power. One closest to the riverside fender, and one to the front by the rad. I always thought one is contsant, and one is power from the switch?
Well, I hooked up the trailer hot wire to the trailer marker lights so I can get home tonight. Any ideas before I go to the dealer?
Did you switch the headlight switch or the multi function switch? My guess is that the problem is the headlight switch. bg
Thanks, yes I did. I put it on my friends truck and it worked fine. I also put his in mine and still the same problem. I'm leaning towards the front control module. My headlights come and fog lights come on with the switch still.
