threw a fan belt,it took out engine speed sensor wire. I replaced ess now have tac. and 1,2,3,gear but no overdrive or cruse control truck won't down shift either. 96 automatic tran.
In the PDC (Powertrain Distribution Center) under the hood, it's fuse "I" labeled "TRANS".I have checked fuses ,repalced tran. relay where is the overdive fuse location I can't seem to find it. Thank you
