I have 2004 3500 dwr 4wheel drive. My problem started when I replaced my rear brakes. I installed new rear rotors, pads, and new factory rebuilt calipers. I bleed the brakes and am sure there is no air in the system. After that my pedal is low and doesn't offer much. The rear brakes do not work at all. I replaced the calibers because the rear passenger one was leaking. I have no lights on in the dash indicating that the ABS or the brakes need serviced. This leads me to beleive that it is a mechanical issue and not an electronic issue. I look for a proportion valve to reset but could not locate any. I was told by someone else that it was internal and part of the ABS system. I am totally at a loss as to what to do next please help. Thank-you.
