HOCummins04
First, I am not a veteran at towing. I am borrowing a friend's flatbed car hauler to retrieve my grandfather's Allis Chalmers WD45 and bring it home to restore. I don't have any trailer brakes. No big deal with empty trailer. Tractor weighs around 4000 pounds. Would definitely be useful coming home with tractor.
I have a Tekonsha Prodigy. The brake has worked correctly last summer, but I do not tow on a regular basis. With nothing hooked up, the display says NC when I try to manually apply brake to just trailer. With the trailer connected, it still says NC when I try to manually apply brake to just trailer. The display never changes like it should when it is connected to trailer.
Setup: Have tow package. There is probably a 2 inch adapter that plugs into factory plugin. There is probably a 1 inch end on the trailer wiring that plugs into above adapter.
Is there any way to test the truck by itself to make sure brake controller is working right?
Is there any way to test trailer to make sure it is working right? I know the brakes are not dragging, because the drum was not even warm to the touch after pulling it home.
Leaving town tomorrow to go to Indiana for DIESEL THUNDER on Saturday. Will pull trailer home Monday or Tuesday. I will be able to check the site on the road, so please help a guy out.
I do not want to drive trailer home 500 miles with probably around 6000 pounds on just truck brakes. :-{}
