My 95 Ram died Saturday evening and I had to have it towed home. After checking things out I confirmed it wasn't getting fuel. The primer on the transfer pump was leaking, so I replaced it (transfer Pmp. ). I have pushed the new primer 300+ times, cracked a injector nut to bleed air, and had the wife turn it over a few times while I watched for fuel to appear. Still nothing, so I loosened the banjo nut on the top of the fuel filter housing, and still no sign of fuel when the wife turned the engine over. I've inspected the fuel lines to the tank, the rubber lines for fuel in and fuel return and all appears to be ok. I don't believe it's a timing issue because of no fuel getting to the injectors. I'm lost and need to get this fixed. I've already lost two days at work. Thanks in advance for any ideas.
