Engine/Transmission (1994 - 1998) Help - NV4500 shifter
2nd Gen Non-Engine/Transmission Door wiring diagram please
Engine/Transmission (1998.5 - 2002) Pacbrake Q & A
Hi,
I am in the process of doing an NV4500 in my 1st gen and have a question about the trans... I need to remove the shifter "stub" on the top of the NV4500 trans to gain some clearance but since this is the first time I have even seen an NV4500 "in person" I am not sure what I sould remove and what I should leave... . I see 2 pair of 4 bolts: 4 at the base of the shift tower and 4 torx "screws" under a small rubber boot... which ones do I need to remove to get the stub out without springs and stuff flying all over the place?
Thanks, Rob
