Help-NV5600 & 271
"600" Bad Injector And Drivetrain Vibration
Which engines make the most power with upgrades, 250hp, 305hp or 325hp?
I need some help finding the right tool to use on the NV5600 filler plug. It looks like a large hex head, so I need to go buy one. What size is it? Also, what size is the hex head needed for the 271 transfer case. I want to change the oils but can't get the filler plugs out. They are not like the differentials that take a standard 3/8 drive extension. TIA
17mm alan wrnch for the 5600. ya can get a bolt that fits a 17mm wrench and double nut and use as a wrench to remove plug instead of buying allen wrnch
I just dug through my nuts and bolts till I found a nut that would fit (SAE). I Just stuck it in the hex shaped plug and used a socket to turn the nut.
I'd like to dope-slap the jerk that decided to make it an allen type (instead of regular) plug. :mad: Everybody who decides to pull the thing out, has to figure out how and with what they will do it.
I bought a male socket, 17mm from AutoZone, here in Phoenix. It was only a couple of bucks, as I recall. It's made by Powerbuilt and is called a "VW, BMW, Porsche Drain Plug" #648438. Hope this helps. Joe.
I found a 17mm allen wrench at my local auto parts store. It was labeled "VW Transmission Filler & Drain Plug Wrench" made by KD Tools, $6. 50. Also you can do a google search for "17mm hex. "
BTW, my truck came with all the fluids full!
