Help Oil Leak
Smarty questions
Transfer Case
Just did an oil change and noticed oil forming on bottom of bell housing and near oil pan gasket(not enough to drip on drive). Anyone else have this and where did leak come from. Any help would be great... . Thank you.
Is it running down the back of the block from the valve cover? I've seen alot of 5. 9s seep oil from the valve cover and have it run down the back of the engine.
-john
-john
I believe my rocker box gasket is leaking at the back. I plan to replace it soon.
Ryan
Just found my leak..... heater / coolant hose (short) on passenger side rear of engine. Leaks down onto the bell housing and travels around to the access, drips on floor. Tighten two hose clamps
