help on 03 2500 needed
Earthroamer 6.0 powerstroke, how well is it surviving?
GM V6-53 fuel pressure ?
just bought a 2003 2500 4x4 HD quad cab, and have lots of questions. for instance, what can i expect lifewise out of the engine. should i put in MARVEL MYSTERY OIL in the fuel at every fillup as suggested? any infor. on this set up would be appreciated!! anything i need to look out for/be aware of? gave my 1994 3/4 ton to my son some years ago and not up on the newer cummins. thanks!!!
-- email address removed --
( I also just emailed this info to: -- email address removed -- )
Your old 1994 had a VERY different injection pump and injection system than your ’03. The P-7100 injection pump used on the ’94-’98. 4 trucks was (is) very resilient to changes in fuel or additives. The same can’t be said for the newer injection systems. The newer injection systems are a lot more sensitive to fuel and additives than ever before. (tighter tolerances, higher pressures, etc. )
If I were you, I’d use either the Stanadyne or Power Service brands. The Power Service brand is more readily available and has worked fine for years in all sorts of injection systems.
All the info you could ever want is right here in this website. Set aside some time and enjoy!
Matt
