2nd Gen Non-Engine/Transmission Help on boat trailer wiring.....
Engine/Transmission (1994 - 1998) gog. springs and idle
2nd Gen Non-Engine/Transmission head light switch prob. on 97 2500
I'm helping a buddy put new trailer lights on - and his aren't color coded. How can you tell from the 4 wire harness in the new light which color is what? For example the left side trailer light also has a clear part under so the license plate is light. It has the following wires:
white green yellow
The right light does not have the yellow but has a green
white green red
When I go to hook up my wires - which one goes where?
Just replaced mine earlier...
Brown... Used for all running lights
Yellow... Drivers side turn and brake
Green... Passangers side turn and brake
White... Ground
The new lights I just put on had 3 wires...
Red... Spliced to the yellow or green
Black... Spliced to the brown
White... wired to the mounting bolt for the light
I purchased a 7 pin trailer plug and a 4 pin wiring kit on Saturday. I got tired of borrowing trailer that never have a long enough 4 pin wire harness to reach the Dodge 7 pin receptacle and decided to make an extension cord.
Well, the 7 pin plug has the following instructions
WHITE = ground
BLUE = brakes
GREEN = tail/license
BLACK = battery charger
RED = left turn /stop
BROWN = right turn/stop
YELLOW = backup/aux
The 4 pin connector set lists
WHITE = ground
YELLOW = left turn/stop
BROWN = tailights
GREEN = right turn/stop
Go figure
