Details here: TDR Privileges
When started sometime the AC won't work until driven a few miles. When this occurs the turn signals are in operative also. Any ideas??? Could this be central timer module or multi function switch?? bg
When you start the engine and turn the a/c on and it does not come on (as I am assuming the blower does not work) wiggle the key a little bit and see if it starts working. Sometimes when the key is cycled to start and then released quickly, the key rotates back a little too far and turns the accessories off, but does not shut the engine off. It may not be the cause of your problem but it is an easy fix if it is.
