"HELP" ? on diesel generator oil
Solar panel ??
meet for Nascar in Atlanta
I just bought a portable diesel generator and the oil recommended is " AGIP sigma,( HD SERIES 3 MIL-L-2104 C API-CD ) and i don't even have a clue what any of the prescribed oil is. I know alot of you out there do, if you can help me out i certainly would appreciate it.
Thanks Mike
Sounds like one of them foreign engines.
Use what ever your use in your truck and you'll be fine, but first check the oil weight, it may take 10w-30 or another weight multi-vis oil
MIL-L-2104: Military spec diesel oil
API-CD: Diesel oil, its like illflem said, "run what is in your truck" and hope the power does'nt go out. ;)
Don't know how much this will help:
From the U. S. Army Tank-automotive and Armaments Command.
Looks like the MIL Spec has been changed to a performance spec.
MIL-L-2104 REWRITTEN AS MIL-PRF-2104
MIL-PRF-2104 Lubricating Oil, Internal Combustion Engine, Combat/Tactical Service.
Further research shows that it is available in different weights and amounts.
MIL-PRF-2104 Lube Oil, I-C Engine, Combat/Tactical Service [OE/HDO-]
9150-00-189-6727 OE/HDO-10 1 qt can
9150-01-177-3988 OE/HDO-10 1 qt bottle
9150-00-186-6668 OE/HDO-10 5 gal can
9150-00-191-2772 OE/HDO-10 55 gal drum
9150-00-186-6681 OE/HDO-30 1 qt can
* 9150-01-433-7988 OE/HDO-30 1 qt can
9150-01-178-4726 OE/HDO-30 1 qt bottle
* 9150-01-433-7974 OE/HDO-30 1 qt bottle
9150-00-188-9858 OE/HDO-30 5 gal can
* 9150-01-433-7986 OE/HDO-30 5 gal can
9150-00-189-6729 OE/HDO-30 55 gal drum
* 9150-01-433-7978 OE/HDO-30 55 gal drum
9150-00-188-9862 OE/HDO-40 55 gal drum
* 9150-01-433-7970 OE/HDO-40 55 gal drum
9150-01-152-4117 OE/HDO-15/40 1 qt can
* 9150-01-422-9346 OE/HDO-15/40 1 qt can
9150-01-178-4725 OE/HDO-15/40 1 qt bottle
* 9150-01-421-1427 OE/HDO-15/40 1 qt bottle
9150-01-152-4118 OE/HDO-15/40 5 gal can
* 9150-01-421-1424 OE/HDO-15/40 5 gal can
9150-01-152-4119 OE/HDO-15/40 55 gal drum
* 9150-01-421-1432 OE/HDO-15/40 55 gal drum
(Note: * designation identifies re-refined products)
Your right illflem,it's a Lombardini engine (20 hp ) from Italy. I use Valvoline Premium Blue 2000 in my motor now . So I will probably use that oil . Thanks all for the help.
Mike
P. S. I read futher on in another instruction manual and it said to refill with API class SG or Sh oil (also Sg/CD, SG/CE, SH/CD or SH/CE)
I had a feeling it was a Lombardini. I had a couple of tractors with Lombardinis and remembered the AGIP rant on the oil fill cap. Rest of the tractor wore out before the engine, they're high quality. Mine were 4 cyl 52 hp air cooled, I used Delo 15w-40 in them.
