I am now installing my Isspro pyro and boost guages. After long debate I have decided to mount my pyro post turbo on the elbow, but have a question or two. The thermo couple I received was the adjustable weld in type. It says to drill a 3/4" and weld the one piece in and screw the other into the welded one. First question I have is would it be a big deal to just drill and tap the elbow and eliminate the weld in piece? Second, what size drill bit and tap? Third question is how far in does a guy put the adjustable thermocouple, I would assume just center the tip, but I don't know? Finally, the last question (or concern). I have actually had the guages mounted on the a-pillar for a couple of weeks, but haven't had the engine side hooked up yet. I noticed my pyro guage has always read about 99 degress right out of the box, what is the deal with this? Thanks in advance for the replies, you guys are a great source to turn to. Now I have to get out to the garage and install my TST power kit, JRE exhaust, and scotty air. This bombing is just too much fun!!!
