HELP on transmission conversion standard to Automatic
1999 F350 swap
Dodge Towing mirrors on a 88-98 Chev/Pic's!!!
As a result of an operation involving the amputationj of my left leg I am unable to drive my 5 speed truck.
My truck is a 98 12 V quad cab 5 speed that would have to be converted to an automatic. Can this be done? What are the problems? Any input would be helpful.
I know this project has probably been discussed before. If some one can point me in the right direction it would be appreciated.
Thank you
Look on Ebay
Look on ebay. Occasionally, you see transmission; transfer, etc.
TRANSMISSION '96
# 7972813431
FLYWHEEL
#7972816668
overdrive unit
7972829956
Your best bet is to find a 47RH not a 47RE. The RE needs electronic support. The RH is a much simpler transmission. I know of 2 people in my area that have done this swap. Amianthus here on the TDR would be a great source of information for this swap.
Sorry to hear about the amputation.
Josh
Josh
Thanks for the info and support. I really appreciate it. Is the 47RH an earlier transmission than the 47RE? Are they compatible?
The 47RH is uses a Hydraulic Gov assy. The 47RE uses more electronics as well as an Electrical Gov pressure sensor. Other than that... The valve bodies are different..... the actual Hardware Guts of the transmissions are the same.
Josh
I have a parts list for the odds and ends. Send me an email and I'd be more than willing to tell you everything I know.
Aron
-- email address removed --
(608)304-0399
