I'm looking at a pickup "camper" that has the option of using an inexpensive window AC (home unit) - and venting it outside... . and running it entirly on 3 HD 12 v batteries. There are a lot of manufactures - such as this one... . Now the Camper Dealer is building a cabinet for this to run in..... some questions... .
1. It uses 5. 5 amps when running on 120..... when she runs through a converter what is the draw?????
2. I have a blank sheet of paper so I can install a bunch of batteries... . What batteries would you use and what would be the run time for say 3 or 4 ?? Now I realize that the AC won't run all the time... ...
3. Please explain the advantage of using a 6 volt battery?
AFS60NX Energy Star 6,000 BTU Window A/C
115 Volts / 60 Hz / 1758 Watts / 5. 5 Amps
