Help P0541 code
Lifted 3500?
Wiring Question
I installes the afe air cleaner and torque tube and now I keep getting a p0541 code. Put the stock box back on and on code. Is it possible that the sensor on the filter is not going into the flow of air in the filter? I love this filter but don't like the code.
Please help. :(
P0541 is "Low voltage on the #1 intake air heater relay". It's set when the signal from the #1 intake air heater output does match the signal from the #1 intake air heater feedback. Possible causes are:
-Loose connection
-Intake air heater relay failed
-signal circuit open from relay to ECM
-signal circuit shorted to ground
-ECM
This has nothing to do with your installation of the torque tube (I assume there is no electrical connection between the tube and the grid heaters).
I will check all connections and the if it doen't fix it I will put the stock box on and take it to the stealership.
Kory:{
