I haven't found anything searching the forums on this so I'll post the question.
I was just out checking/adjusting my rear brakes (wheels and brake drums off) and I noticed a little bit of rotational play in the left side hub. With the drum on, I can gently rotate the wheel hub a few degrees either way before I notice the drive line starting to move. The amount of play is maybe 1/8 to 3/16 inch rotational movement at the outer rim of the drum. This is not due to the drum slopping on the wheel studs.
On the right side, there is virtually no play at all. The slightest rotation of the hub causes the drive line to move.
So the questons are: what is this likely to be a symptom of, how can I pin it down for sure, and what is the solution?
TIA!
Jay K.
TIA!
Jay K.
