Hello all, Have a question, My transmission is "locked up"(converter) When I come to a stop it will kill the engine. The solenoid is not engaged (I removed the connector from the side of the transmission). If I get the truck rolling it will shift, down shift and seem to use the lockup function (Turn on and off) if I am in OD and press the button on the shifter to force third gear it will downshift than loose a little more rpm when it seems to go into lockup third gear... BUT coming to a stop it will stall the engine. Stock converter / rebuilt transmission with 5000 miles, TQ with 20,000 miles? not sure. Fluid looks great, no codes using three key turn method. . Thinking the converter pooped the bed???????
THANKS FOR THE HELP
THANKS FOR THE HELP
