Need input prior to order, hopefully next week
1. Air ride, OEM or aftermarket. Besides warranty it seems that aftermarket installed with wireless system probably as much but has ability to adjust on fly and L to R. Does the factory setup use a softer spring in the back with the air such that unloaded ride would be better then hit the bags as needed? Seems like it would be a good idea but doesn't seem that dodge thought of this.
2. Laramie vs Limited. Fully loaded the only diff I can find that may be "major" is that the leather is much nicer in the limited and it comes with, in my opinion, much nicer 20inch rims
3. I converted my 5th wheel to disc brakes with electric over hydraulic. Are the initial problems with the onboard screen setup and function of the built in trailer brake controller resolved. I don't want to run a new brake controller
4. Alternator, the limited comes with 220. I will not have a snow plow, etc. Seems like that is enough?
5. 5th wheel prep: I was planning on having factory prep but by aftermarket Reese hitch which I believe is available for the wider puck footprint compared to my current hitch.
6. Going Aisin for sure and I hear they will not offer in 2018, not sure I care
I am thinking of going with Dave Smith in ID this time. I am close, in Reno and it seems they will go straight to what they call their wholesale. How would I know. What info is available to check actual wholesale prices.
Thanks
Thanks
