I had a shop install a rebuilt P7100 215Hp pump for me. The problem is the truck is now missing at idle. The tech believes there is a stuck plunger on #2, because there is barely any fuel coming out at the pump.
The pump timing was set at 13*, the tech bumped the timing up seven clicks to a total of 20* timing. There is absolutely no bottom end power at all now! I told him I wanted it at 15. 5* because I tow a lot.
Truck has #10 and 3GSK installed, any recommendations on the pump?
